    • Search
    coolpi 4b running PIPPY project
    Maker
    3
    16
    269
      jack_admin last edited by jack_admin
      开源四足仿生机器狗
      https://www.waveshare.net/wiki/PIPPY
      https://www.bilibili.com/video/BV1VV411n7FE/?zw
      现已兼容coolpi 4b
      https://gitee.com/yanyitech/pyppi.git
      产品介绍
      这一款是专门为树莓派设计的开源四足仿生机器狗。扩展板将OLED,舵机电机驱动电路,九轴姿态传感器,电池保护电路等集成在一起,免去你焊接电路的烦恼,支持免卸载充电,无需反复拆卸电池。支持视频监控,视觉巡线,超声波避障,自平衡控制,运动检测,颜色识别等功能。
      特点
      板载两节2600mAh 18650电池,支持边充边放
      板载HY2120 + AO4406A锂电池保护电路,具有防过充、防过放、防过流和短路保护功能
      板载APW7313稳压芯片,可给树莓派提供稳定的5V电压
      板载高精度九轴运动姿态监测传感器ICM20948,可实现机器人姿态自平衡
      板载0.91寸128×32分辨率OLED,实时显示小车IP地址,电量等情况
      板载AINA219采集芯片,方便实时监控电池电压,充电电流
      实操使用coolpi 4b + ubuntu20 desktop
        在安装过程中,会遇到python opencv错误
        sudo pip3 install -i http://pypi.douban.com/simple/ --trusted-host=pypi.douban.com/simple opencv-contrib-python==3.4.11.45
              [ 83%] Building CXX object modules/xfeatures2d/CMakeFiles/opencv_xfeatures2d.dir/src/boostdesc.cpp.o
              /tmp/pip-install-r3olluyq/opencv-contrib-python_519e0e398ed74b4b813452e2fef1a717/opencv_contrib/modules/xfeatures2d/src/boostdesc.cpp:654:20: fatal error: boostdesc_bgm.i: No such file or directory
                654 |           #include "boostdesc_bgm.i"
              compilation terminated.
        参考网上解决方法(https://www.cnblogs.com/zhang-hongbo/p/12859405.html)
        把下列压缩包解压到目录opencv_contrib/modules/xfeatures2d/src/下即可。
        压缩包地址:
        链接:https://pan.baidu.com/s/17XhXX_cLz46bsj9ZWRkNIg
        提取码:p50x
        boostdesc_bgm_extra.zip
          继续编译,遇到问题
             [ 98%] Building CXX object modules/stitching/CMakeFiles/opencv_stitching.dir/src/autocalib.cpp.o
                In file included from /tmp/pip-install-d2d32b_5/opencv-contrib-python_28af57cc6bde4c2cb142a1ef1a9dbf03/opencv/modules/stitching/include/opencv2/stitching.hpp:49,
                                 from /tmp/pip-install-d2d32b_5/opencv-contrib-python_28af57cc6bde4c2cb142a1ef1a9dbf03/opencv/modules/stitching/src/precomp.hpp:59,
                                 from /tmp/pip-install-d2d32b_5/opencv-contrib-python_28af57cc6bde4c2cb142a1ef1a9dbf03/opencv/modules/stitching/src/autocalib.cpp:43:
                /tmp/pip-install-d2d32b_5/opencv-contrib-python_28af57cc6bde4c2cb142a1ef1a9dbf03/opencv/modules/stitching/include/opencv2/stitching/detail/matchers.hpp:52:12: fatal error: opencv2/xfeatures2d/cuda.hpp: No such file or directory
                   52 | #  include "opencv2/xfeatures2d/cuda.hpp"
            bg8wj last edited by
            python3 setup正常完成。
            运行webServer.py
            定位 ultra.py中这个语句出错
            GPIO.setup(Tr, GPIO.OUT,initial=GPIO.LOW)
            提示SystemError: more argument specifiers than keyword list entries (remaining format:'i')
            大法师 1 Reply Last reply Reply Quote 0
            • 大法师
              大法师 @bg8wj last edited by
              @bg8wj
              还得适配优化,某些api没使用到
                creat_ap 运行后 无法建立 ap方式。同样液晶屏也没法显示IP地址。
                • 大法师
                  @bg8wj 命令行启动运行,应该有报错信息
                    bg8wj @大法师 last edited by
                    @大法师 蹊跷的就是编译https://github.com/oblique/create_ap这个是成功的。但是启动web server 没有提前了。然后就进程就卡住了。创建ap这里失败。
                    • 大法师
                      @bg8wj
                      https://www.cool-pi.com/topic/136/coolpi-4b-python3-gpio-operation-compatable-with-raspberry-pi/11
                      gpio python需要安装。
                        @大法师 已经安装 20.04原生系统只能安装python3.9的轮子。
                          狗套件已经购买能否给个打包的系统映像文件。尝试安装了很多次都开在 webserver上。没法创建ap 故此无法编译。我再ubuntu20.04 系统上使用。液晶屏以及舵机初始化都正常。oled就是没法显示IP地址。
                          大法师 J 2 Replies Last reply Reply Quote 0
                          • 大法师
                            大法师 @bg8wj last edited by 大法师
                            @bg8wj 这个套件目前没在我手上,当时是运行sta模式测试的。你的oled屏显示正常,只是取ip的代码没执行成功吧,给wifi配置连接一个本地网络
                            B 2 Replies Last reply Reply Quote 0
                              jack_admin @bg8wj last edited by
                              @bg8wj 约个时间,远程登录看看错误信息
                                @大法师 谢谢。就是WiFi模块感觉没有驱动成功。我这几天尝试打个WiFi的补丁。
                                  bg8wj @jack_admin last edited by
                                  @jack_admin 好。论坛中Ubuntu20.4的系统,我再尝试打个WiFi的驱动补丁试试。有没有weichat联系方式。我加你,约时间远程。
                                    @大法师 更新内核ap+sta后貌似正常 。
                                    新的问题出现 运行过程中提示
                                    global cap_v4l.cpp:1119 tryIoctl VIDEOIO(V4L2:/dev/video0): select() timeout.
                                    Exception in thread Thread-4:
