Introduction to COOL PI CM5 interface
Top-level interface
The 2X20 pin interface is compatible with CP4 and integrates multiple UART, I2C, SPI, CAN and other functions.
Three function keys are PWR, RST and LOADER.
2X2 PIN POE connector,such as CP4.
30pin fpc vertical connector can directly drive standard 30PIN EDP interface LCD. Resolution up to 3840 * 2160
The MICRO HDMI-RX interface can support up to 4KP60 video signal input.
TF card with self-locking.
Two native USB3.0 interfaces, one of which supports OTG function.
Two Gigabit Ethernet interfaces, one of which supports POE function.
Two HDMI2.1 interfaces with a maximum resolution of 8K.
Stereo headphone stand with MIC input function.
Two native USB2.0 interfaces.
One TYPEC power supply interface, consistent with CP4.
The external power interface of 2PIN can support DC power input.
1 standard PCIE 4X connector, currently only supports PCIE3.0 2X/1X mode.
SSD interface, only PCIE-M2-2242 size hard disk is supported.
Standard 7PIN SATA3.0 interface, 4PIN power interface.
M.2 WIFI module interface, supporting multiple general WIFI modules.
Dual MIPI LCD interfaces support simultaneous output of two MIPI interface LCDs. The resolution of a single LCD is up to 1920 * 1200. It supports the MIPI DSC function.
Four independent MIPI camera interfaces support four camera inputs at the same time. It can be configured as 2X4LINE or 4X2LINE mode.
Bot-level interface
One 30PIN EDP interface can directly drive LCD output.
MXM 314PIN core board connector.
Welcome to put forward good suggestions. We can consider revising them.
@george 您好,请问一下底板资料啥时候出来
@george 不错不错
@george 就是俩usb3 是不是稍微少了点呀 板子上留几个usb的接线口也行呀
@george 哦 还有俩usb2的 应该够用了,
@Twsuts 底板已经在制版中。预计月底可以出来。
@顾真牛 有标准PCIE接口,USB3.0不够可以扩展。外置4个USB接口,2个U2 两个U3。一般场景可以满足。
@Twsuts 正常需要初步验证和测试完成以后,底板资料才可以开放。目前核心板已经是稳定版本。
@george 已经拿到板子在测试验证了吧 放些图吧
@顾真牛 这个还没有贴片回来,拿到后会第一时间反馈。
@george 提问关于COOL PI CM5是否支持Intel AX210NGW 网卡问题?谢谢
@likeshixi
支持的,需要配置内核驱动,另外补充相应的firmware文件iwlwifi-ty-59.601f3a66.0.tgz 解压到/lib/firmwaregithub拉取内核同步编译试下,已加入该模块配置
安装了AX210wifi网卡,怎么配置内核驱动,请给一个详细的教程
安装了AX210wifi网卡,怎么配置内核驱动,请给一个详细的教程,而且文件iwlwifi-ty-59.601f3a66.0.tgz链接打不开 -
@wuming 驱动默认已经集成。只需要拷贝BIN文件进去。晚点发链接出来,先帮忙上传一下dmesg
@george WIFI固件下载链接如下 ,根据日志信息把对应firmware拷贝到机器/lib/firmware目录即可。
git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
@george :但是没有root 账户密码,连U盘都不能打开。
三个*.ucode文件已经拷贝到/lib/firmware文件夹中,重启系统还是没有反应,看不到wifi的相关信息。
@wuming dmesg输出传一份
@jack_admin :我这么把dmesg命令生成的文件传给你。
@wuming 直接上传附件就好了
@wuming dmesg |grep iwl
@wuming 你的内核版本不对!内核请更新到最新,使用cm5-evb-v11的配置编译
@george 我的这个版本不行吗?
