Solved 系统无法备份、还原
试了两个不同的U盘 都不能进行还原
这个有什么要求?需要什么型号的U盘? -
卡在logo那里 屏幕也没有进度条 -
https://www.cool-pi.com/topic/247/cool-pi-4b-cm5-探索快速安装系统新方法/144?page=8
备份:
修改U盘默认配置文件extlinux/extlinux.conf原始
label Linux coolpi
kernel /Image
initrd /initrd.img修改后
label Linux coolpi
kernel /Image
initrd /initrd-backup.img -
这个就是原来安装盘的镜像 还原的结果
没有替换我备份出来的系统 -
还原不了
wait for device. AT2S9C wait for external disk device...........mount: mounting /dev/sda1 on /tmp/boot failed: No such file or directory Could not mount src boot partition [ 46.717516] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 46.723433] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 46.834180] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 46.840093] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 46.950848] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 46.956760] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.067514] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.073428] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.184183] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.190097] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.300850] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.306765] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.417517] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.423431] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.534184] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.540099] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.650851] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.656765] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.767518] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.773432] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 47.884183] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 47.890098] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 48.000850] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 48.006765] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 48.117521] rk3x-i2c fec90000.i2c: timeout, ipd: 0x00, state: 3 [ 48.123435] es8316 7-0010: ASoC: error at soc_component_write_no_lock on es8316.7-0010: -110 [ 48.324850] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000290 [ 48.333624] Mem abort info: [ 48.336412] ESR = 0x96000005 [ 48.339461] EC = 0x25: DABT (current EL), IL = 32 bits [ 48.344762] SET = 0, FnV = 0 [ 48.347808] EA = 0, S1PTW = 0 [ 48.350942] Data abort info: [ 48.353814] ISV = 0, ISS = 0x00000005 [ 48.357640] CM = 0, WnR = 0 [ 48.360600] user pgtable: 4k pages, 39-bit VAs, pgdp=0000000106a93000 [ 48.367028] [0000000000000290] pgd=0000000000000000, p4d=0000000000000000, pud=0000000000000000 [ 48.375712] Internal error: Oops: 96000005 [#1] SMP [ 48.380577] Modules linked in: [ 48.383625] CPU: 1 PID: 1 Comm: reboot Not tainted 5.10.110 #21 [ 48.389530] Hardware name: RK3588 CoolPi CM5 EVB Board (DT) [ 48.395090] pstate: 60400009 (nZCv daif +PAN -UAO -TCO BTYPE=--) [ 48.401087] pc : fxgmac_disable_rx+0x108/0x120 [ 48.405519] lr : fxgmac_disable_rx+0x90/0x120 [ 48.409864] sp : ffffffc01252bb70 [ 48.413168] x29: ffffffc01252bb70 x28: ffffff8100829d00 [ 48.418468] x27: 0000000000000000 x26: 0000000000000001 [ 48.423767] x25: 0000000000000000 x24: ffffff8104ab68c0 [ 48.429066] x23: 0000000000000000 x22: 0000000000000001 [ 48.434365] x21: ffffff8104ab6000 x20: 0000000000000004 [ 48.439665] x19: ffffff8104ab68c0 x18: 0000000000000002 [ 48.444964] x17: 0000000000000000 x16: 00000072403c3448 [ 48.450264] x15: ffffffc0113e9630 x14: ffffffc0120e6e38 [ 48.455563] x13: 0001cbfd4dde56d1 x12: 0000000000000016 [ 48.460862] x11: 0000000000000000 x10: 0000000000000001 [ 48.466162] x9 : ffffffc010b30974 x8 : 000000000005ad12 [ 48.471462] x7 : 00000000000002c5 x6 : 0000000000ff2b3b [ 48.476760] x5 : ffffffc011956600 x4 : 0000000000000000 [ 48.482060] x3 : 0000000000000000 x2 : 0000000000000000 [ 48.487359] x1 : 00000000000003e8 x0 : 0000000000000004 [ 48.492658] Call trace: [ 48.495098] fxgmac_disable_rx+0x108/0x120 [ 48.499184] fxgmac_net_powerdown+0x164/0x214 [ 48.503531] __fxgmac_shutdown+0x68/0xe4 [ 48.507444] fxgmac_shutdown+0x48/0xb8 [ 48.511185] pci_device_shutdown+0x40/0x50 [ 48.515272] device_shutdown+0x150/0x260 [ 48.519185] __do_sys_reboot+0x1dc/0x260 [ 48.523097] __arm64_sys_reboot+0x30/0x40 [ 48.527098] el0_svc_common.constprop.0+0xa4/0x2a0 [ 48.531877] do_el0_svc+0x78/0xa0 [ 48.535183] el0_svc+0x20/0x30 [ 48.538229] el0_sync_handler+0xe8/0xf0 [ 48.542054] el0_sync+0x1a0/0x1c0 [ 48.545360] [ 48.545360] PC: 0xffffffc010b309ec: [ 48.550312] 07ec f9450660 b9400000 d50331bf 2a0003e1 ca010021 b5000001 d50332bf 121e7400 [ 48.558476] 080c f9450661 b9000020 b94aea60 52800015 34000100 2a1503e1 aa1303e0 97ffff6a [ 48.566639] 082c 110006b5 b94aea60 6b15001f 54ffff48 b94ad260 f9456661 35000260 14000014 [ 48.574802] 084c f9401020 91002000 b9400000 d50331bf 2a0003e2 ca020042 b5000002 d50332bf [ 48.582964] 086c f9401022 121f7800 91002042 b9000040 b94ad260 11000694 910b0021 6b14001f [ 48.591126] 088c 54000069 f9414820 b5fffdc0 52800000 a94153f3 f94013f5 a8c37bfd d50323bf [ 48.599290] 08ac d65f03c0 f9450660 91002000 b9400000 d50331bf 2a0003e0 ca000000 b5000000 [ 48.607452] 08cc 12800000 a94153f3 f94013f5 a8c37bfd d50323bf d65f03c0 d503245f aa1e03e9 [ 48.615614] 08ec d503201f d503233f a9be7bfd 910003fd a90153f3 aa0003f3 f9450401 b9400021 [ 48.623776] 090c d50331bf 2a0103e0 ca000000 b5000000 d50332bf 121f7821 120a7421 f9450660 [ 48.631939] 092c b9000001 91001000 b9400000 d50331bf 2a0003e1 ca010021 b5000001 d50332bf [ 48.640101] 094c f9450661 120f7800 91001021 b9000020 b94aea60 34000120 52800014 2a1403e1 [ 48.648264] 096c aa1303e0 97ffff18 11000694 b94aea60 6b14001f 54ffff48 d50332bf f9450660 [ 48.656427] 098c 91028000 b900001f b94ad260 f9456662 340002c0 52800003 14000012 f9401041 [ 48.664590] 09ac 91002021 b9400021 d50331bf 2a0103e0 ca000000 b5000000 d50332bf f9401040 [ 48.672752] 09cc 121f7821 91002000 b9000001 b94ad260 11000463 910b0042 6b03001f 54000069 [ 48.680915] 09ec* f9414840 b5fffdc0 a94153f3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 [ 48.689078] 0a0c d503201f d503233f a9bb7bfd d5384101 910003fd a90153f3 d2800002 a9025bf5 [ 48.697240] 0a2c aa0003f5 91150020 f9400001 f90027e1 d2800001 913562b3 aa1303e0 d2820001 [ 48.705402] 0a4c 97ed9371 12003c00 713ffc1f 540008c8 52906416 a90363f7 91011bf7 52800018 [ 48.713565] 0a6c 72bdb716 52800034 d503201f 52800004 12800002 52800003 79008fe0 f240087f [ 48.721729] 0a8c 54000061 13037c64 3864cae4 4a020086 53017c42 4a160045 11000463 f24000df [ 48.729891] 0aac 53017c84 1a8210a2 7100307f 54fffe81 2a2203e3 11000400 5ac00063 531c7c63 [ 48.738054] 0acc 92403c02 d2820001 aa1303e0 1ac32283 2a180063 12003c78 97ed934b 12003c00 [ 48.746217] 0aec 713ffc1f 54fffc49 2a1803e1 2a1803e3 a94363f7 f94506a0 91016000 b9400000 [ 48.754380] 0b0c d50331bf 2a0003e2 ca020042 b5000002 d50332bf f94506a2 12103c00 2a030000 [ 48.762542] 0b2c 91016042 b9000040 d0006b80 9122c000 942133fe d5384100 f94027e1 f942a002 [ 48.770705] 0b4c eb020021 d2800002 54000141 52800000 a94153f3 a9425bf5 a8c57bfd d50323bf [ 48.778867] 0b6c d65f03c0 52800003 52800001 17ffffe2 a90363f7 9421f500 d503245f aa1e03e9 [ 48.787030] 0b8c d503201f d503233f a9bd7bfd 910003fd a90153f3 aa0003f3 aa0103f4 f90013f5 [ 48.795193] 0bac f9400815 d5033e9f f9402c20 52801c02 b9409021 9ba20021 d50332bf f9401260 [ 48.803356] 0bcc f9400421 91008000 b9000001 b946daa2 375002e2 b94b0ea0 340001e0 b9428260 [ 48.811519] [ 48.811519] LR: 0xffffffc010b30974: [ 48.816470] 0774 ca010021 b5000001 51000442 72100814 540000a0 35fffec2 f9450660 91045000 [ 48.824632] 0794 14000049 b94ae660 52800004 34000260 d503201f 531a6480 91342000 14000002 [ 48.832795] 07b4 340007e2 f9450661 8b000021 b9400021 d50331bf 2a0103e3 ca030063 b5000003 [ 48.840958] 07d4 51000442 3727fee1 b94ae660 11000484 6b04001f 54fffe08 f9450660 b9400000 [ 48.849121] 07f4 d50331bf 2a0003e1 ca010021 b5000001 d50332bf 121e7400 f9450661 b9000020 [ 48.857283] 0814 b94aea60 52800015 34000100 2a1503e1 aa1303e0 97ffff6a 110006b5 b94aea60 [ 48.865445] 0834 6b15001f 54ffff48 b94ad260 f9456661 35000260 14000014 f9401020 91002000 [ 48.873607] 0854 b9400000 d50331bf 2a0003e2 ca020042 b5000002 d50332bf f9401022 121f7800 [ 48.881769] 0874 91002042 b9000040 b94ad260 11000694 910b0021 6b14001f 54000069 f9414820 [ 48.889931] 0894 b5fffdc0 52800000 a94153f3 f94013f5 a8c37bfd d50323bf d65f03c0 f9450660 [ 48.898093] 08b4 91002000 b9400000 d50331bf 2a0003e0 ca000000 b5000000 12800000 a94153f3 [ 48.906255] 08d4 f94013f5 a8c37bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f [ 48.914419] 08f4 a9be7bfd 910003fd a90153f3 aa0003f3 f9450401 b9400021 d50331bf 2a0103e0 [ 48.922582] 0914 ca000000 b5000000 d50332bf 121f7821 120a7421 f9450660 b9000001 91001000 [ 48.930744] 0934 b9400000 d50331bf 2a0003e1 ca010021 b5000001 d50332bf f9450661 120f7800 [ 48.938907] 0954 91001021 b9000020 b94aea60 34000120 52800014 2a1403e1 aa1303e0 97ffff18 [ 48.947069] 0974* 11000694 b94aea60 6b14001f 54ffff48 d50332bf f9450660 91028000 b900001f [ 48.955232] 0994 b94ad260 f9456662 340002c0 52800003 14000012 f9401041 91002021 b9400021 [ 48.963395] 09b4 d50331bf 2a0103e0 ca000000 b5000000 d50332bf f9401040 121f7821 91002000 [ 48.971557] 09d4 b9000001 b94ad260 11000463 910b0042 6b03001f 54000069 f9414840 b5fffdc0 [ 48.979719] 09f4 a94153f3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f [ 48.987882] 0a14 a9bb7bfd d5384101 910003fd a90153f3 d2800002 a9025bf5 aa0003f5 91150020 [ 48.996045] 0a34 f9400001 f90027e1 d2800001 913562b3 aa1303e0 d2820001 97ed9371 12003c00 [ 49.004207] 0a54 713ffc1f 540008c8 52906416 a90363f7 91011bf7 52800018 72bdb716 52800034 [ 49.012369] 0a74 d503201f 52800004 12800002 52800003 79008fe0 f240087f 54000061 13037c64 [ 49.020533] 0a94 3864cae4 4a020086 53017c42 4a160045 11000463 f24000df 53017c84 1a8210a2 [ 49.028696] 0ab4 7100307f 54fffe81 2a2203e3 11000400 5ac00063 531c7c63 92403c02 d2820001 [ 49.036858] 0ad4 aa1303e0 1ac32283 2a180063 12003c78 97ed934b 12003c00 713ffc1f 54fffc49 [ 49.045021] 0af4 2a1803e1 2a1803e3 a94363f7 f94506a0 91016000 b9400000 d50331bf 2a0003e2 [ 49.053183] 0b14 ca020042 b5000002 d50332bf f94506a2 12103c00 2a030000 91016042 b9000040 [ 49.061345] 0b34 d0006b80 9122c000 942133fe d5384100 f94027e1 f942a002 eb020021 d2800002 [ 49.069508] 0b54 54000141 52800000 a94153f3 a9425bf5 a8c57bfd d50323bf d65f03c0 52800003 [ 49.077671] [ 49.077671] SP: 0xffffffc01252bb70: [ 49.082622] b970 00e86258 ffffff81 4215a600 9fb334b6 1252b9a0 ffffffc0 1003bcdc ffffffc0 [ 49.090785] b990 96000005 00000000 1252ba20 ffffffc0 1252b9e0 ffffffc0 113ac7c0 ffffffc0 [ 49.098948] b9b0 1252ba20 ffffffc0 96000005 00000000 123fb000 ffffffc0 00000290 00000000 [ 49.107111] b9d0 1252ba20 ffffffc0 fee64400 ffffff82 1252ba10 ffffffc0 113acefc ffffffc0 [ 49.115274] b9f0 04ab68c0 ffffff81 ffffffff 0000007f 1252bb70 ffffffc0 10b309ec ffffffc0 [ 49.123438] ba10 1252bb50 ffffffc0 10012408 ffffffc0 00000004 00000000 000003e8 00000000 [ 49.131600] ba30 00000000 00000000 00000000 00000000 00000000 00000000 11956600 ffffffc0 [ 49.139762] ba50 00ff2b3b 00000000 000002c5 00000000 0005ad12 00000000 10b30974 ffffffc0 [ 49.147925] ba70 00000001 00000000 00000000 00000000 00000016 00000000 4dde56d1 0001cbfd [ 49.156087] ba90 120e6e38 ffffffc0 113e9630 ffffffc0 403c3448 00000072 00000000 00000000 [ 49.164251] bab0 00000002 00000000 04ab68c0 ffffff81 00000004 00000000 04ab6000 ffffff81 [ 49.172413] bad0 00000001 00000000 00000000 00000000 04ab68c0 ffffff81 00000000 00000000 [ 49.180576] baf0 00000001 00000000 00000000 00000000 00829d00 ffffff81 1252bb70 ffffffc0 [ 49.188738] bb10 10b30974 ffffffc0 1252bb70 ffffffc0 10b309ec ffffffc0 60400009 00000000 [ 49.196900] bb30 1252bb70 ffffffc0 10b30974 ffffffc0 ffffffff 0000007f 00000003 00000000 [ 49.205062] bb50 1252bb70 ffffffc0 10b309ec ffffffc0 00000000 00000000 00000000 00000000 [ 49.213224] bb70* 1252bb90 ffffffc0 10b389c4 ffffffc0 04ac1bc0 ffffff81 00000004 00000000 [ 49.221387] bb90 1252bbf0 ffffffc0 11393e34 ffffffc0 0485f800 ffffff81 04ab6000 ffffff81 [ 49.229549] bbb0 1252bc57 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.237711] bbd0 11886f08 ffffffc0 0485f930 ffffff81 00000000 00000000 00829d00 ffffff81 [ 49.245874] bbf0 1252bc30 ffffffc0 11393ef8 ffffffc0 0485f800 ffffff81 122c9cd0 ffffffc0 [ 49.254038] bc10 022238b0 ffffff81 12466310 ffffffc0 123fb030 ffffffc0 00000000 00000000 [ 49.262200] bc30 1252bc60 ffffffc0 10779f60 ffffffc0 0485f800 ffffff81 122c9cd0 ffffffc0 [ 49.270363] bc50 022238b0 ffffff81 4215a600 9fb334b6 1252bc80 ffffffc0 10a4ab60 ffffffc0 [ 49.278525] bc70 0485f8b8 ffffff81 0485f8b0 ffffff81 1252bcd0 ffffffc0 100cca0c ffffffc0 [ 49.286688] bc90 00000000 00000000 120e3210 ffffffc0 120e2e78 ffffffc0 fee1dead 00000000 [ 49.294851] bcb0 ec696050 0000007f 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.303013] bcd0 1252be20 ffffffc0 100ccac0 ffffffc0 1252beb0 ffffffc0 0000008e 00000000 [ 49.311176] bcf0 00000000 00000000 113d0a80 ffffffc0 123fb000 ffffffc0 1001ff44 ffffffc0 [ 49.319338] bd10 00000001 ffffffc0 1244ba50 ffffffc0 1252bd40 ffffffc0 113b08cc ffffffc0 [ 49.327500] bd30 ffffffff 7fffffff 05b6d800 ffffff81 1252bd60 ffffffc0 113b38d4 ffffffc0 [ 49.335663] bd50 05b6d870 ffffff81 00000000 00000000 1252bd80 ffffffc0 102e90d8 ffffffc0 [ 49.343827] [ 49.343827] X5: 0xffffffc011956600: [ 49.348778] 6400 255b3701 362e362d 63205d73 206c6c61 75716572 5f747365 2879656b 2c73252c [ 49.356940] 6420 0a297325 00000000 74656e26 64783e2d 6f6c2e70 00006b63 2d737826 74756d3e [ 49.365102] 6440 6e007865 782f7465 782f7064 632e6b73 00000000 00000000 5f6b7378 0070616d [ 49.373265] 6460 2f74656e 2f706478 5f6b7378 66667562 6f6f705f 00632e6c 6c696146 74206465 [ 49.381428] 6480 6964206f 6c626173 657a2065 632d6f72 2179706f 0000000a 6c756f43 6f6e2064 [ 49.389591] 64a0 69662074 6420646e 6d5f616d 66207061 6420726f 63697665 00000065 00000000 [ 49.397754] 64c0 76697244 64207265 6e206469 4420746f 6d20414d 7a207061 2d6f7265 79706f63 [ 49.405917] 64e0 66756220 73726566 74656e00 7064782f 6b73782f 6675625f 6f705f66 632e6c6f [ 49.414080] 6500 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.422242] 6520 00000000 00000000 00000000 00000000 100e0de0 ffffffc0 00000000 00000000 [ 49.430405] 6540 00000000 00000000 100e0d74 ffffffc0 100e0d10 ffffffc0 100e0c70 ffffffc0 [ 49.438567] 6560 100e0cd0 ffffffc0 100e0c50 ffffffc0 100e0c30 ffffffc0 00000000 00000000 [ 49.446731] 6580 00000000 00000000 100da040 ffffffc0 00000000 00000000 00000000 00000000 [ 49.454893] 65a0 100e0c90 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.463056] 65c0 100e0d64 ffffffc0 100e0d54 ffffffc0 00000000 00000000 100e0cb0 ffffffc0 [ 49.471219] 65e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.479381] 6600* 00000001 00000000 100e8924 ffffffc0 100e7a50 ffffffc0 100e7174 ffffffc0 [ 49.487544] 6620 100e7214 ffffffc0 100e6db0 ffffffc0 100ec970 ffffffc0 100e8200 ffffffc0 [ 49.495707] 6640 100e68d4 ffffffc0 100ec514 ffffffc0 100e3ed0 ffffffc0 100e5b60 ffffffc0 [ 49.503869] 6660 00000000 00000000 100da040 ffffffc0 100e2610 ffffffc0 100e9600 ffffffc0 [ 49.512032] 6680 100e72a0 ffffffc0 100e7010 ffffffc0 100e3310 ffffffc0 100e5bf0 ffffffc0 [ 49.520195] 66a0 100e5fb0 ffffffc0 100e2190 ffffffc0 100e1c40 ffffffc0 100e6b90 ffffffc0 [ 49.528358] 66c0 100e5d60 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.536521] 66e0 00000001 00000000 100efde0 ffffffc0 100f0e20 ffffffc0 100ee380 ffffffc0 [ 49.544684] 6700 00000000 00000000 100ee2c0 ffffffc0 100ee630 ffffffc0 100f0ea0 ffffffc0 [ 49.552847] 6720 100ee0d0 ffffffc0 100f13e0 ffffffc0 100eea60 ffffffc0 00000000 00000000 [ 49.561009] 6740 100f07e4 ffffffc0 100da040 ffffffc0 100eecb4 ffffffc0 100ef9f4 ffffffc0 [ 49.569172] 6760 100f0cd0 ffffffc0 00000000 00000000 00000000 00000000 100edfc4 ffffffc0 [ 49.577334] 6780 100ee500 ffffffc0 100edee0 ffffffc0 100eda84 ffffffc0 100f0874 ffffffc0 [ 49.585497] 67a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.593659] 67c0 00000000 00000000 100f4fa0 ffffffc0 100f65a0 ffffffc0 100f6370 ffffffc0 [ 49.601821] 67e0 00000000 00000000 100f2140 ffffffc0 100f2f60 ffffffc0 100f63d0 ffffffc0 [ 49.609984] [ 49.609984] X9: 0xffffffc010b30974: [ 49.614934] 0774 ca010021 b5000001 51000442 72100814 540000a0 35fffec2 f9450660 91045000 [ 49.623097] 0794 14000049 b94ae660 52800004 34000260 d503201f 531a6480 91342000 14000002 [ 49.631260] 07b4 340007e2 f9450661 8b000021 b9400021 d50331bf 2a0103e3 ca030063 b5000003 [ 49.639422] 07d4 51000442 3727fee1 b94ae660 11000484 6b04001f 54fffe08 f9450660 b9400000 [ 49.647584] 07f4 d50331bf 2a0003e1 ca010021 b5000001 d50332bf 121e7400 f9450661 b9000020 [ 49.655746] 0814 b94aea60 52800015 34000100 2a1503e1 aa1303e0 97ffff6a 110006b5 b94aea60 [ 49.663908] 0834 6b15001f 54ffff48 b94ad260 f9456661 35000260 14000014 f9401020 91002000 [ 49.672071] 0854 b9400000 d50331bf 2a0003e2 ca020042 b5000002 d50332bf f9401022 121f7800 [ 49.680233] 0874 91002042 b9000040 b94ad260 11000694 910b0021 6b14001f 54000069 f9414820 [ 49.688396] 0894 b5fffdc0 52800000 a94153f3 f94013f5 a8c37bfd d50323bf d65f03c0 f9450660 [ 49.696560] 08b4 91002000 b9400000 d50331bf 2a0003e0 ca000000 b5000000 12800000 a94153f3 [ 49.704722] 08d4 f94013f5 a8c37bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f [ 49.712883] 08f4 a9be7bfd 910003fd a90153f3 aa0003f3 f9450401 b9400021 d50331bf 2a0103e0 [ 49.721046] 0914 ca000000 b5000000 d50332bf 121f7821 120a7421 f9450660 b9000001 91001000 [ 49.729209] 0934 b9400000 d50331bf 2a0003e1 ca010021 b5000001 d50332bf f9450661 120f7800 [ 49.737371] 0954 91001021 b9000020 b94aea60 34000120 52800014 2a1403e1 aa1303e0 97ffff18 [ 49.745533] 0974* 11000694 b94aea60 6b14001f 54ffff48 d50332bf f9450660 91028000 b900001f [ 49.753697] 0994 b94ad260 f9456662 340002c0 52800003 14000012 f9401041 91002021 b9400021 [ 49.761860] 09b4 d50331bf 2a0103e0 ca000000 b5000000 d50332bf f9401040 121f7821 91002000 [ 49.770023] 09d4 b9000001 b94ad260 11000463 910b0042 6b03001f 54000069 f9414840 b5fffdc0 [ 49.778185] 09f4 a94153f3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f [ 49.786348] 0a14 a9bb7bfd d5384101 910003fd a90153f3 d2800002 a9025bf5 aa0003f5 91150020 [ 49.794510] 0a34 f9400001 f90027e1 d2800001 913562b3 aa1303e0 d2820001 97ed9371 12003c00 [ 49.802672] 0a54 713ffc1f 540008c8 52906416 a90363f7 91011bf7 52800018 72bdb716 52800034 [ 49.810835] 0a74 d503201f 52800004 12800002 52800003 79008fe0 f240087f 54000061 13037c64 [ 49.818997] 0a94 3864cae4 4a020086 53017c42 4a160045 11000463 f24000df 53017c84 1a8210a2 [ 49.827160] 0ab4 7100307f 54fffe81 2a2203e3 11000400 5ac00063 531c7c63 92403c02 d2820001 [ 49.835323] 0ad4 aa1303e0 1ac32283 2a180063 12003c78 97ed934b 12003c00 713ffc1f 54fffc49 [ 49.843485] 0af4 2a1803e1 2a1803e3 a94363f7 f94506a0 91016000 b9400000 d50331bf 2a0003e2 [ 49.851648] 0b14 ca020042 b5000002 d50332bf f94506a2 12103c00 2a030000 91016042 b9000040 [ 49.859810] 0b34 d0006b80 9122c000 942133fe d5384100 f94027e1 f942a002 eb020021 d2800002 [ 49.867973] 0b54 54000141 52800000 a94153f3 a9425bf5 a8c57bfd d50323bf d65f03c0 52800003 [ 49.876136] [ 49.876136] X14: 0xffffffc0120e6e38: [ 49.881174] 6c38 00001388 00000000 00000000 000005dc 0000000a 00000000 00000000 00000000 [ 49.889337] 6c58 00000000 00000000 00000000 00000000 00000000 000005dc 0000000a 00000000 [ 49.897499] 6c78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.905662] 6c98 00000000 00000000 120e6ca0 ffffffc0 120e6ca0 ffffffc0 0000001e 00000000 [ 49.913825] 6cb8 00000000 00000000 00000000 00000000 120e6cc8 ffffffc0 120e6cc8 ffffffc0 [ 49.921988] 6cd8 00000000 00000000 00000000 00000000 120e6ce8 ffffffc0 120e6ce8 ffffffc0 [ 49.930149] 6cf8 00000000 00000000 00000000 00000000 120e6d08 ffffffc0 120e6d08 ffffffc0 [ 49.938312] 6d18 0000005a 00400000 00000064 00000000 ffffffff 00000001 00000000 00000000 [ 49.946474] 6d38 00000000 00000000 120e6d40 ffffffc0 120e6d40 ffffffc0 120e6d78 ffffffc0 [ 49.954636] 6d58 00000000 00000000 00000000 00000000 120e6d68 ffffffc0 120e6d68 ffffffc0 [ 49.962799] 6d78 10a83bd0 ffffffc0 100faa14 ffffffc0 00000000 00000000 00000000 00000000 [ 49.970962] 6d98 00000000 00000000 00000000 00000000 00000000 00000000 117af210 ffffffc0 [ 49.979125] 6db8 100faa00 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 49.987287] 6dd8 00000000 00000000 00000000 00000000 00000000 00000000 117af218 ffffffc0 [ 49.995449] 6df8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.003612] 6e18 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.011774] 6e38* 00000020 0000ba7e 113e9630 ffffffc0 00000020 00000000 fffea070 00000000 [ 50.019937] 6e58 117b0770 ffffffc0 00000000 00000000 00000000 0000016d 00157400 ffffff81 [ 50.028099] 6e78 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.036262] 6e98 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.044424] 6eb8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.052587] 6ed8 1179e0d8 ffffffc0 00000000 00000000 00000000 0000016d 120e6e58 ffffffc0 [ 50.060750] 6ef8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.068912] 6f18 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.077074] 6f38 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.085237] 6f58 121cfde0 ffffffc0 120e7030 ffffffc0 00000000 00000000 00000000 00000000 [ 50.093399] 6f78 120e6f78 ffffffc0 120e6f78 ffffffc0 120e6f88 ffffffc0 120e6f88 ffffffc0 [ 50.101562] 6f98 120e6f98 ffffffc0 120e6f98 ffffffc0 00000001 0000000b 00000003 00000000 [ 50.109724] 6fb8 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.117886] 6fd8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.126049] 6ff8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.134212] 7018 00000000 00000000 11b75850 ffffffc0 11b75740 ffffffc0 10104750 ffffffc0 [ 50.142375] [ 50.142375] X15: 0xffffffc0113e9630: [ 50.147413] 9430 08d3dcb0 0b21642c 0e38e38e 11111111 656c6573 665f7463 626c6c61 5f6b6361 [ 50.155575] 9450 00007172 00000000 63726f66 6f635f65 7461706d 656c6269 7570635f 6c615f73 [ 50.163739] 9470 65776f6c 74705f64 00000072 00000000 3b9aca00 00000000 65686373 00000064 [ 50.171902] 9490 74617473 6b5f6369 735f7965 5f776f6c 00636e69 00000000 65686373 66635f64 [ 50.180064] 94b0 65705f73 646f6972 6d69745f 00007265 00000005 00000000 117af220 ffffffc0 [ 50.188226] 94d0 00000005 00000000 117af238 ffffffc0 00000005 00000000 117af248 ffffffc0 [ 50.196389] 94f0 00000005 00000000 117af258 ffffffc0 00000001 00000000 117af268 ffffffc0 [ 50.204552] 9510 00000006 00000000 117af278 ffffffc0 00000005 00000000 117af290 ffffffc0 [ 50.212715] 9530 00000005 00000000 117af2a8 ffffffc0 00000006 00000000 117af2c0 ffffffc0 [ 50.220878] 9550 00000005 00000000 117af2d0 ffffffc0 00000004 00000000 117af2e0 ffffffc0 [ 50.229041] 9570 00000006 00000000 117af2f8 ffffffc0 00000006 00000000 117af308 ffffffc0 [ 50.237204] 9590 74617473 6b5f6369 735f7965 5f776f6c 00636e69 00000000 74617473 6b5f6369 [ 50.245366] 95b0 735f7965 5f776f6c 00636564 00000000 695f6470 0074696e 65686373 6e655f64 [ 50.253529] 95d0 79677265 7465735f 00000000 00000000 74617473 6b5f6369 645f7965 62617369 [ 50.261692] 95f0 0000656c 00000000 74617473 6b5f6369 655f7965 6c62616e 00000065 00000000 [ 50.269854] 9610 ffffffff eac0c6e6 d744fcc9 c5672a10 b504f333 a5fed6a9 9837f050 8b95c1e3 [ 50.278018] 9630* ffffffff fa83b2da f5257d14 efe4b99a eac0c6e6 e5b906e6 e0ccdeeb dbfbb796 [ 50.286180] 9650 d744fcc9 d2a81d91 ce248c14 c9b9bd85 c5672a10 c12c4cc9 bd08a39e b8fbaf46 [ 50.294342] 9670 b504f333 b123f581 ad583ee9 a9a15ab4 a5fed6a9 a2704302 9ef5325f 9b8d39b9 [ 50.302504] 9690 9837f050 94f4efa8 91c3d373 8ea4398a 8b95c1e3 88980e80 85aac367 82cd8698 [ 50.310666] 96b0 5f746573 746c6570 00000000 00000000 6f747561 756f7267 72635f70 65746165 [ 50.318829] 96d0 00000000 00000000 100ff9b0 ffffffc0 100ff790 ffffffc0 100ffa40 ffffffc0 [ 50.326991] 96f0 100ff7b0 ffffffc0 00000000 00000000 10319bc4 ffffffc0 10319a84 ffffffc0 [ 50.335153] 9710 100ffda0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.343315] 9730 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.351478] 9750 00000000 00000000 00000000 00000000 00000000 00000000 100ffb00 ffffffc0 [ 50.359640] 9770 00000000 00000000 10318c50 ffffffc0 00000000 00000000 00000000 00000000 [ 50.367803] 9790 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.375965] 97b0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.384127] 97d0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.392289] 97f0 00000000 00000000 117af558 ffffffc0 117b0780 ffffffc0 117b0790 ffffffc0 [ 50.400452] 9810 117b07a0 ffffffc0 117b07b0 ffffffc0 117b07c0 ffffffc0 117b07d8 ffffffc0 [ 50.408615] [ 50.408615] X19: 0xffffff8104ab68c0: [ 50.413653] 66c0 04ab66c0 ffffff81 04ab66c0 ffffff81 00000000 00000000 00000000 00000000 [ 50.421816] 66e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.429978] 6700 04ab6700 ffffff81 04ab6700 ffffff81 00000000 00000000 00000000 00000000 [ 50.438141] 6720 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.446303] 6740 04ab6740 ffffff81 04ab6740 ffffff81 11957360 ffffffc0 04ab6780 ffffff81 [ 50.454466] 6760 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.462628] 6780 11650820 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.470791] 67a0 00000000 00000000 00000000 00000000 00010000 0000ffff 00000000 00000000 [ 50.478953] 67c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.487116] 67e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.495278] 6800 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.503440] 6820 00000000 00000000 00000000 00000000 00000000 00000000 04ab6838 ffffff81 [ 50.511602] 6840 04ab6838 ffffff81 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.519766] 6860 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.527928] 6880 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.536090] 68a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.544252] 68c0* 04ab6000 ffffff81 0485f8b0 ffffff81 0485f800 ffffff81 00000000 00000000 [ 50.552415] 68e0 10b33d10 ffffffc0 10b32ca0 ffffffc0 10b2f874 ffffffc0 10b2e6d0 ffffffc0 [ 50.560578] 6900 10b2e720 ffffffc0 10b315d0 ffffffc0 10b2fc54 ffffffc0 10b2f700 ffffffc0 [ 50.568741] 6920 10b2d1d4 ffffffc0 10b30480 ffffffc0 10b2d2d0 ffffffc0 10b308e4 ffffffc0 [ 50.576904] 6940 10b2e2d0 ffffffc0 10b2e3b4 ffffffc0 10b2e4a4 ffffffc0 10b2e4e4 ffffffc0 [ 50.585066] 6960 10b2e520 ffffffc0 10b2e564 ffffffc0 10b2e5f0 ffffffc0 10b2e624 ffffffc0 [ 50.593228] 6980 10b2e660 ffffffc0 10b2e694 ffffffc0 10b30fe0 ffffffc0 10b30c74 ffffffc0 [ 50.601390] 69a0 10b2cef0 ffffffc0 10b32af0 ffffffc0 10b2f6a0 ffffffc0 10b2f640 ffffffc0 [ 50.609553] 69c0 10b318a0 ffffffc0 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.617715] 69e0 10b2f5c0 ffffffc0 10b2d404 ffffffc0 10b2f4c0 ffffffc0 10b2d3e0 ffffffc0 [ 50.625878] 6a00 10b2f3e4 ffffffc0 10b2d4d0 ffffffc0 10b2d4b0 ffffffc0 10b30b84 ffffffc0 [ 50.634041] 6a20 10b32aa0 ffffffc0 10b32860 ffffffc0 00000000 00000000 10b2d180 ffffffc0 [ 50.642203] 6a40 10b2cf34 ffffffc0 10b2cfc0 ffffffc0 10b2f374 ffffffc0 10b2f310 ffffffc0 [ 50.650365] 6a60 10b2d010 ffffffc0 10b2d090 ffffffc0 10b30a04 ffffffc0 10b2d4f0 ffffffc0 [ 50.658527] 6a80 10b2d570 ffffffc0 10b2d590 ffffffc0 10b2d5d0 ffffffc0 10b2d610 ffffffc0 [ 50.666689] 6aa0 10b2d690 ffffffc0 10b2d710 ffffffc0 10b2d790 ffffffc0 10b2d810 ffffffc0 [ 50.674851] [ 50.674851] X21: 0xffffff8104ab6000: [ 50.679890] 5e00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.688053] 5e20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.696216] 5e40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.704378] 5e60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.712541] 5e80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.720703] 5ea0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.728865] 5ec0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.737027] 5ee0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.745190] 5f00 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.753353] 5f20 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.761515] 5f40 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.769678] 5f60 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.777840] 5f80 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.786002] 5fa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.794164] 5fc0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.802326] 5fe0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.810488] 6000* 30687465 00000000 00000000 00000000 03f30600 ffffff81 00000000 00000000 [ 50.818651] 6020 00000000 00000000 00000000 00000000 13b10000 ffffffc0 0000007f 00000000 [ 50.826813] 6040 0000000e 00000000 04b24048 ffffff81 01537048 ffffff81 04ab6058 ffffff81 [ 50.834976] 6060 04ab6058 ffffff81 04ab6068 ffffff81 04ab6068 ffffff81 04ab6078 ffffff81 [ 50.843138] 6080 04ab6078 ffffff81 04ab6088 ffffff81 04ab6088 ffffff81 04ab6098 ffffff81 [ 50.851301] 60a0 04ab6098 ffffff81 04ab60a8 ffffff81 04ab60a8 ffffff81 04ab60b8 ffffff81 [ 50.859463] 60c0 04ab60b8 ffffff81 00114b93 00000180 00194b93 02000380 00114b93 00000180 [ 50.867626] 60e0 00194033 00000180 10000001 00000000 00000001 00000000 00000000 00000000 [ 50.875789] 6100 00000002 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.883951] 6120 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.892113] 6140 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.900276] 6160 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.908438] 6180 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.916601] 61a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.924763] 61c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000001 [ 50.932925] 61e0 00000000 00000000 00000000 00000000 11539dd8 ffffffc0 115399d8 ffffffc0 [ 50.941087] [ 50.941087] X24: 0xffffff8104ab68c0: [ 50.946125] 66c0 04ab66c0 ffffff81 04ab66c0 ffffff81 00000000 00000000 00000000 00000000 [ 50.954287] 66e0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 50.962450] 6700 04ab6700 ffffff81 04ab6700 ffffff81 00000000 00000000 00000000 00000000
@jugg 4B和CM5不能混用。看log,你的U盘是4b的dtb、内核
已经改过来了 -
结果就是崩溃 -
@jugg 找一个能正常安装系统的U盘,确认安装没问题之后,把配置文件改为备份功能
现在就是在CM5的安装盘里面改的
U盘我用来装WIn10都没问题 -
