@george Armbian, for example
I'd like to test Android or OpenEuler, for example ... but I don't know how to install "preinstalled" images .
It seems is not enough to use BalenaEtcher to create a SD/TF to start/run. Help?
Thanks for RebornOS Team support!
https://github.com/RebornOS-Developers
User can download RebornOS image for testing now.
RebornOS ARM Cool Pi 4
Thank you ... but my cool pi doesn't start with this image
RebornOS-ARM-cpi4-2023-04-17.img.xz
I've tried flashing my 128 GB eMMC and a SD card without success
Previously I've used with ARMBIAN img without any problem.
Thank you in advance
@Pharizna said in cool pi 4b RebornOS support:
RebornOS-ARM-cpi4-2023-04-17.img.xzI've tried flashing my 128 GB eMMC and a SD card without success
The problem is bigger now since my device doesn't boot up with RebornOS, Armbian or Ubuntu. It's stuck in an endless loop with the CoolPi logo.
What can I do? It's as if the "boot files lost? I'm just copying the ARMBIAN, UBUNTU image with BalenaEtcher to the eMMC, isn't that enough?
@Pharizna Try using a USB disk or SDcard to start
@Pharizna
wipe or format emmc and sd partition and try again. also can use udisk boot for auto install ubuntu system.
@george Thanks
I've tried with a SD card ... and the problem remains
@jack_admin Thanks!
I wipe/format the eMMC and installed again the RebornOS image and now WORKS!
I thought that Balena format previously the device ... but don't
Hi again
Now, I have my CoolPi working fine with RebornOS but... without wireless connection.
Wired connections works for Internet but when I tried to enable my wireless connection always ask for my password. CoolPi see without any problems all available wireless networks but it does not accept the password
@Pharizna
install online through ethernet and restart system.
Thank you @jack_admin but the problem remains
I format the eMMC and flashed the RebornOS with Balena. Then I installed online through the LAN (wired connection), reboot the device.
The problem remains and I can't connect to my LAN using Wireless. It doesn't accept my credentials that are using in my another devices, of course
I tried creating an access point in my iPhone with the same problem
Has anyone managed to use WiFi on Cool Pi 4B with RebornOS?
@Pharizna Please take a photo of the front of your machine.
Of course @george
Here are some of the pictures of my next review of this device in my website www.pcdemano.com
@Pharizna Can other systems, such as ubuntu, be connected properly
Hello, RebornOS dev here
I just want to address some things
Known issues
you should also follow development here
https://discord.gg/cU5s6MPpQH - discord server we use to communicate
https://github.com/RebornOS-Developers/lxqt-cpi4-image - main stuff used for the image creation
https://github.com/RebornOS-Developers/lxqt-cpi4-image/releases/latest - latest image release
@rippanda12 Thank you for the info.
RebornOS is the "only" linux where Kodi last version can be installed
We hope you solve the WiFi "problem" as soon as possible. THANKS!
Android firmware can be used with Etcher now. Please use the latest download link onedrive or 百度网盘.
Do you mean that on Android the wifi does not work yet?
@Pharizna ubuntu,armbian and android can be normal using wifi&bt.
@rippanda12 Only for your "info"... as you know WiFi works in the RebornOS of the RADXA Rock 5B (rockchip-rk3588)
