coolpi 4b support ov5647 camera module
OV5647模块适用于Cool Pi 4b
Use buildroot system image for test camera ov5647.
离线刷机镜像
在线刷机镜像
Great job!
Which OS? (armbian or ubuntu?)
Does it work with v4l2 or gstreamer?
Any updates on PI HQ camera?
Thanks! -
@大法师 ubuntu 20.04 下如何挂载?安装上了但是加载不出来
@大法师 没有。dev 下无vido 。dmesg 运行无响应。
@bg8wj 需要更新内核驱动
@大法师 刷入提供的最新的ubuntu20.04 执行dmesg
10.083104] ov5647 8-0036: Unsupported clock frequency: 24000000
[ 10.089129] ov5647: probe of 8-0036 failed with error -22如何配置?
另最新的20.04 ros2 opencv miniconda 安装正常了 -
@bg8wj github已更新内核驱动代码。二进制执行文件明天测试好再上传
root@coolpi:/home/coolpi# ls -l /dev/video* crw-rw----+ 1 root video 81, 0 Jan 27 23:26 /dev/video0 crw-rw----+ 1 root video 81, 1 Jan 27 23:26 /dev/video1 crw-rw----+ 1 root video 81, 10 Jan 27 23:26 /dev/video10 crw-rw----+ 1 root video 81, 11 Jan 27 23:26 /dev/video11 crw-rw----+ 1 root video 81, 12 Jan 27 23:26 /dev/video12 crw-rw----+ 1 root video 81, 13 Jan 27 23:26 /dev/video13 crw-rw----+ 1 root video 81, 14 Jan 27 23:26 /dev/video14 crw-rw----+ 1 root video 81, 15 Jan 27 23:26 /dev/video15 crw-rw----+ 1 root video 81, 16 Jan 27 23:26 /dev/video16 crw-rw----+ 1 root video 81, 17 Jan 27 23:26 /dev/video17 crw-rw----+ 1 root video 81, 18 Jan 27 23:26 /dev/video18 crw-rw----+ 1 root video 81, 19 Jan 27 23:26 /dev/video19 crw-rw----+ 1 root video 81, 2 Jan 27 23:26 /dev/video2 crw-rw----+ 1 root video 81, 3 Jan 27 23:26 /dev/video3 crw-rw----+ 1 root video 81, 4 Jan 27 23:26 /dev/video4 crw-rw----+ 1 root video 81, 5 Jan 27 23:26 /dev/video5 crw-rw----+ 1 root video 81, 6 Jan 27 23:26 /dev/video6 crw-rw----+ 1 root video 81, 7 Jan 27 23:26 /dev/video7 crw-rw----+ 1 root video 81, 8 Jan 27 23:26 /dev/video8 crw-rw----+ 1 root video 81, 9 Jan 27 23:26 /dev/video9 lrwxrwxrwx 1 root root 7 Jan 27 23:26 /dev/video-camera0 -> video11 root@coolpi:/home/coolpi# root@coolpi:/home/coolpi# dmesg | grep ov564 [ 11.285152] ov5648 8-0036: driver version: 00.01.05 [ 11.285181] ov5648 8-0036: Failed to get power-gpios, maybe no use [ 11.285193] ov5648 8-0036: Failed to get reset-gpios, maybe no use [ 11.285205] ov5648 8-0036: Failed to get pwdn-gpios [ 11.285305] ov5648 8-0036: supply dovdd not found, using dummy regulator [ 11.285372] ov5648 8-0036: supply dvdd not found, using dummy regulator [ 11.285409] ov5648 8-0036: lane_num(2) pixel_rate(84000000) [ 11.285416] ov5648 8-0036: could not get default pinstate [ 11.290827] ov5648 8-0036: could not get sleep pinstate [ 11.299689] ov5648 8-0036: Detected OV005647 sensor [ 11.299707] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5 root@coolpi:/home/coolpi#
@大法师 Hi, thanks for your effort!
A suggestion, why not doc your work as a tutorial?
So that everyone can help you debug the code. -
@大法师 非常感谢。麻烦您。如可以给个安装指导。我汇总成教程。coolpi 4b 非常强大,我再学习移植一些 raspbeery 4b的项目到coolpi上。
@bg8wj 谢谢!我们验证好了会同步发布出来。这款主板还有很多功能可以挖掘,需要更多的伙伴一起共赢!
暂时未重新打包刷机镜像,可以先独立更新内核驱动包。
coolpi@coolpi:~$ sudo dpkg -i coolpi-kernel_1.0.0_aarch64.deb coolpi@coolpi:~$ sync coolpi@coolpi:~$ sudo reboot
重启系统,如有连接ov5647摄像头,可以识别到video设备。
coolpi@coolpi:~$ sudo apt install v4l-utils coolpi@coolpi:~$ v4l2-ctl --list-devices rkisp-statistics (platform: rkisp): /dev/video18 /dev/video19 rkcif (platform:rkcif-mipi-lvds2): /dev/video0 /dev/video1 /dev/video2 /dev/video3 /dev/video4 /dev/video5 /dev/video6 /dev/video7 /dev/video8 /dev/video9 /dev/video10 rkisp_mainpath (platform:rkisp0-vir0): /dev/video11 /dev/video12 /dev/video13 /dev/video14 /dev/video15 /dev/video16 /dev/video17
@大法师 谢谢。
請問是否有機會支援 VEYE 系列的模組? 像是 IMX462 之類 (http://www.veye.cc/产品/veye-mipi-imx462-2/#tab-id-2)
畢竟 VEYE 也是國產之光,國內也比較容易買得到
Hi, I tried the new kernel with two OV5647 camera.
It looks the default configuration is not correct.
The command I usedsudo v4l2-ctl --verbose -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat='NV12' --stream-mmap=4 --set-selection=target=crop,flags=0,top=0,left=0,width=1920,height=1080 --stream-to=out1.yuv ffplay out1.yuv -pixel_format nv12 -video_size 1920x1080
The system message
@Ubuntu:~$ dmesg | grep 'ov5' [ 7.644913] ov5648 8-0036: driver version: 00.01.05 [ 7.644958] ov5648 8-0036: Failed to get power-gpios, maybe no use [ 7.644976] ov5648 8-0036: Failed to get reset-gpios, maybe no use [ 7.644994] ov5648 8-0036: Failed to get pwdn-gpios [ 7.645126] ov5648 8-0036: supply dovdd not found, using dummy regulator [ 7.645216] ov5648 8-0036: supply dvdd not found, using dummy regulator [ 7.645268] ov5648 8-0036: lane_num(2) pixel_rate(84000000) [ 7.645277] ov5648 8-0036: could not get default pinstate [ 7.650710] ov5648 8-0036: could not get sleep pinstate [ 7.660168] ov5648 8-0036: Detected OV005647 sensor [ 7.660205] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m01_f_ov5648 8-0036:bus type 5 [ 123.522013] ov5648 8-0036: ov5648_s_stream(997) enter! [ 123.522018] ov5648 8-0036: stream on!!! [ 123.574530] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1 [ 123.577105] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400 [ 141.109425] ov5648 8-0036: ov5648_s_stream(997) enter! [ 141.109431] ov5648 8-0036: stream off!!! [ 352.460709] ov5648 8-0036: ov5648_s_stream(997) enter! [ 352.460714] ov5648 8-0036: stream on!!! [ 352.506940] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1 [ 352.508804] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400 [ 359.915797] ov5648 8-0036: ov5648_s_stream(997) enter! [ 359.915807] ov5648 8-0036: stream off!!! [ 522.868438] ov5648 8-0036: ov5648_s_stream(997) enter! [ 522.868438] ov5648 8-0036: stream on!!! [ 522.907120] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1 [ 522.908828] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400 [ 527.994503] ov5648 8-0036: ov5648_s_stream(997) enter! [ 527.994509] ov5648 8-0036: stream off!!! [ 567.407434] ov5648 8-0036: ov5648_s_stream(997) enter! [ 567.407435] ov5648 8-0036: stream on!!! [ 567.448267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9a0901, val:0x1 [ 567.450267] ov5648 8-0036: ov5648_set_ctrl Unhandled id:0x9f0905, val:0x400 [ 572.471164] ov5648 8-0036: ov5648_s_stream(997) enter! [ 572.471167] ov5648 8-0036: stream off!!!
@Ubuntu:~$ sudo v4l2-ctl --list-devices rkisp-statistics (platform: rkisp): /dev/video18 /dev/video19 rkcif-mipi-lvds2 (platform:rkcif): /dev/media0 rkcif (platform:rkcif-mipi-lvds2): /dev/video0 /dev/video1 /dev/video2 /dev/video3 /dev/video4 /dev/video5 /dev/video6 /dev/video7 /dev/video8 /dev/video9 /dev/video10 rkisp_mainpath (platform:rkisp0-vir0): /dev/video11 /dev/video12 /dev/video13 /dev/video14 /dev/video15 /dev/video16 /dev/video17 /dev/media1
Ubuntu:~$ sudo media-ctl -p -d /dev/media0 Media controller API version 5.10.110 Media device information ------------------------ driver rkcif model rkcif-mipi-lvds2 serial bus info hw revision 0x0 driver version 5.10.110 Device topology - entity 1: stream_cif_mipi_id0 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video0 pad0: Sink <- "rockchip-mipi-csi2":1 [ENABLED] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 5: stream_cif_mipi_id1 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video1 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [ENABLED] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 9: stream_cif_mipi_id2 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video2 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [ENABLED] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 13: stream_cif_mipi_id3 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video3 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [ENABLED] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 17: rkcif_scale_ch0 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video4 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [ENABLED] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 21: rkcif_scale_ch1 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video5 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [ENABLED] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 25: rkcif_scale_ch2 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video6 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [ENABLED] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 29: rkcif_scale_ch3 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video7 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [ENABLED] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 33: rkcif_tools_id0 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video8 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [ENABLED] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [] - entity 37: rkcif_tools_id1 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video9 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [ENABLED] <- "rockchip-mipi-csi2":11 [] - entity 41: rkcif_tools_id2 (1 pad, 11 links) type Node subtype V4L flags 0 device node name /dev/video10 pad0: Sink <- "rockchip-mipi-csi2":1 [] <- "rockchip-mipi-csi2":2 [] <- "rockchip-mipi-csi2":3 [] <- "rockchip-mipi-csi2":4 [] <- "rockchip-mipi-csi2":5 [] <- "rockchip-mipi-csi2":6 [] <- "rockchip-mipi-csi2":7 [] <- "rockchip-mipi-csi2":8 [] <- "rockchip-mipi-csi2":9 [] <- "rockchip-mipi-csi2":10 [] <- "rockchip-mipi-csi2":11 [ENABLED] - entity 45: rockchip-mipi-csi2 (12 pads, 122 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev0 pad0: Sink [fmt:SBGGR10_1X10/2592x1944 field:none crop.bounds:(0,0)/2592x1944 crop:(0,0)/2592x1944] <- "rockchip-csi2-dphy0":1 [ENABLED] pad1: Source -> "stream_cif_mipi_id0":0 [ENABLED] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad2: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [ENABLED] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad3: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [ENABLED] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad4: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [ENABLED] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad5: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [ENABLED] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad6: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [ENABLED] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad7: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [ENABLED] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad8: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [ENABLED] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad9: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [ENABLED] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [] pad10: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [ENABLED] -> "rkcif_tools_id2":0 [] pad11: Source -> "stream_cif_mipi_id0":0 [] -> "stream_cif_mipi_id1":0 [] -> "stream_cif_mipi_id2":0 [] -> "stream_cif_mipi_id3":0 [] -> "rkcif_scale_ch0":0 [] -> "rkcif_scale_ch1":0 [] -> "rkcif_scale_ch2":0 [] -> "rkcif_scale_ch3":0 [] -> "rkcif_tools_id0":0 [] -> "rkcif_tools_id1":0 [] -> "rkcif_tools_id2":0 [ENABLED] - entity 58: rockchip-csi2-dphy0 (2 pads, 2 links) type V4L2 subdev subtype Unknown flags 0 device node name /dev/v4l-subdev1 pad0: Sink [fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none] <- "m01_f_ov5648 8-0036":0 [ENABLED] pad1: Source -> "rockchip-mipi-csi2":0 [ENABLED] - entity 63: m01_f_ov5648 8-0036 (1 pad, 1 link) type V4L2 subdev subtype Sensor flags 0 device node name /dev/v4l-subdev2 pad0: Source [fmt:SBGGR10_1X10/2592x1944@10000/150000 field:none] -> "rockchip-csi2-dphy0":0 [ENABLED]
@nickliu
ubuntu or armbian version need verify and then release. -
@大法师 The latest ubuntu22.04 image can already support this camera.
20230210-ubuntu-22.04-preinstalled-desktop-arm64-coolpi.rar
V4L2-TEST can start the camera by operating the video11 node
摄像头亮度特别暗,202307041916-ubuntu-22.04-server-arm64-cp4b.zip
@wangyx server版本应该没有安装camera isp服务。你试下桌面是不是好的
sudo apt install -y camera-engine-rkaiq gstreamer1.0-rockchip gstreamer1.0-plugins-good gstreamer1.0-plugins-bad gstreamer1.0-plugins-ugly
@大法师 有效,多谢
如果遇到这个问题的话:
coolpi@car-c:~$ gst-launch-1.0 v4l2src device=/dev/video11 ! video/x-raw,format=NV12,width=1920,height=1080,framerate=25/1 ! videoflip method=vertical-flip ! mpph264enc ! rtspclientsink latency=0 location=rtsp://192.168.0.100:554/test Setting pipeline to PAUSED ... ERROR: Pipeline doesn't want to pause. ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video11' for reading and writing. Additional debug info: v4l2_calls.c(621): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: system error: Permission denied Setting pipeline to NULL ... Freeing pipeline ...
执行命令前加上sudo,给上权限,摄像头就能用了
@gongxing 可以试下把你的用户加入到video组
这是我接的CSI的摄像头
用V4L2-TEST无法打开 选的/dev/video11
需要怎么样才能打开 内核是我自己编译的
这是用V4L2-TEST打开时demsg打印的
