Coolpi uses UMS to update the system
Coolpi supports UMS to update emmc firmware, as follows:
- Update the latest versions of loader and uboot images. You can also synchronize uboot code and compile it yourself.
git clone https://github.com/yanyitech/coolpi-loader cd coolpi-loader ./build-uboot.sh cp4b
- Connect a dual A port USB cable to the computer and the upper USB 3.0 interface. Plug in the power and press the power button three times, and the machine will enter UMS mode.
- Use Etcher software to update the software.
这应该是刷成功了吧?
双头USB-A线没带,还没有办法实测
@edwardzhou 是的,这样是成功了。
@george 是不是只支持windows? 我在Mac上没有发现这个设备
@edwardzhou 先确认WIN是否OK,MAC暂时还没有测试,这个回头我们跟一下。
@george 请问一下这个刷的img是build-fatboot.sh脚本打包的固件嘛
@Twsuts 这个固件是百度网盘或者onedrive下载的系统img格式固件。不是内核编译脚本生成的。
