cool pi nano rv1106 with ubuntu22 server
Booting system from tf card
COOLPI LOADER BY YANYI(Jul 11 2023) DRAM: 256 MiB Using default environment boot mode: None eth0: ethernet@ffa80000 Autoboot in 1 seconds switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 192 bytes read in 6 ms (31.3 KiB/s) 1: Linux coolpi Retrieving file: /initrd32.img reading /initrd32.img 35643864 bytes read in 2980 ms (11.4 MiB/s) Retrieving file: /vmlinuz reading /vmlinuz 2173048 bytes read in 185 ms (11.2 MiB/s) append: root=LABEL=writable rw rootfstype=ext4 console=ttyS0,115200n81 net.ifnames=0 rtleth=ethaddr:be:50:64:cc:c8:53 Retrieving file: /rv1106-cpnano.dtb reading /rv1106-cpnano.dtb 32649 bytes read in 7 ms (4.4 MiB/s) ## Flattened Device Tree blob at 0x00c00000 Booting using the fdt blob at 0x00c00000 Using Device Tree in place at 00c00000, end 00c0af88 Adding bank: 0x00000000 - 0x10000000 (size: 0x10000000) Starting kernel ... ubuntu login: root Welcome to Ubuntu 22.04.2 LTS (GNU/Linux 5.10.110 armv7l) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage System information as of Fri Sep 9 18:51:14 UTC 2022 System load: 0.353515625 Swap usage: 0% Users logged in: 0 Usage of /: 33.9% of 3.49GB Temperature: 44.6 C Memory usage: 23% Processes: 54 Expanded Security Maintenance for Applications is not enabled. 0 updates can be applied immediately. Enable ESM Apps to receive additional future security updates. See https://ubuntu.com/esm or run: sudo pro status The programs included with the Ubuntu system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Ubuntu comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. root@ubuntu:~# cat /proc/cpuinfo processor : 0 model name : ARMv7 Processor rev 5 (v7l) BogoMIPS : 69.82 Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xc07 CPU revision : 5 Hardware : Generic DT based system Revision : 0000 Serial : d3bd77b45eddde16 root@ubuntu:~#
cool pi nano rv1106 啥时候推出来?
@3395438 资料整理中。同时近期会推出cool pi 笔记本产品
@大法师 加油,RV1106小巧,又有NPU,可玩性很高
@3395438 确实是好芯片
这个啥时候出啊 都这么久了 要到明年?
