cool pi arm board with ubuntu create bootable udisk
usb-creator-gtk - create a startup using a CD or disc image (for GNOME)
coolpi@coolpi:~$ sudo apt install usb-creator-gtk [sudo] password for coolpi: Reading package lists... Done Building dependency tree... Done Reading state information... Done The following packages were automatically installed and are no longer required: appmenu-gtk-module-common appmenu-gtk2-module appmenu-gtk3-module haveged kactivities-bin kactivitymanagerd kde-cli-tools kde-cli-tools-data kscreen libappmenu-gtk2-parser0 libappmenu-gtk3-parser0 libhavege2 libkf5activities5 libkf5calendarevents5 libkf5kcmutils-data libkf5kcmutils5 libkf5kirigami2-5 libkf5plasma5 libkf5plasmaquick5 libkf5pty-data libkf5pty5 libkf5quickaddons5 libkf5su-bin libkf5su-data libkf5su5 libkworkspace5-5 plasma-framework qml-module-org-kde-kconfig qml-module-org-kde-kquickcontrols qml-module-org-kde-kquickcontrolsaddons sddm sddm-theme-debian-maui Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: gir1.2-dbusmenu-glib-0.4 gir1.2-dee-1.0 gir1.2-udisks-2.0 gir1.2-unity-7.0 usb-creator-common The following NEW packages will be installed: gir1.2-dbusmenu-glib-0.4 gir1.2-dee-1.0 gir1.2-udisks-2.0 gir1.2-unity-7.0 usb-creator-common usb-creator-gtk 0 upgraded, 6 newly installed, 0 to remove and 342 not upgraded. Need to get 111 kB of archives. After this operation, 818 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 gir1.2-dbusmenu-glib-0.4 arm64 16.04.1+18.10.20180917-0ubuntu8 [6616 B] Get:2 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 gir1.2-dee-1.0 arm64 1.2.7+17.10.20170616-6ubuntu4 [13.6 kB] Get:3 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 gir1.2-udisks-2.0 arm64 2.9.4-1ubuntu2 [31.8 kB] Get:4 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 gir1.2-unity-7.0 arm64 7.1.4+19.04.20190319-6build1 [22.5 kB] Get:5 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 usb-creator-common all 0.3.13 [13.9 kB] Get:6 http://mirrors.aliyun.com/ubuntu-ports jammy/main arm64 usb-creator-gtk all 0.3.13 [22.9 kB] Fetched 111 kB in 7s (15.6 kB/s) Selecting previously unselected package gir1.2-dbusmenu-glib-0.4:arm64. (Reading database ... 329536 files and directories currently installed.) Preparing to unpack .../0-gir1.2-dbusmenu-glib-0.4_16.04.1+18.10.20180917-0ubuntu8_arm64.deb ... Unpacking gir1.2-dbusmenu-glib-0.4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Selecting previously unselected package gir1.2-dee-1.0. Preparing to unpack .../1-gir1.2-dee-1.0_1.2.7+17.10.20170616-6ubuntu4_arm64.deb ... Unpacking gir1.2-dee-1.0 (1.2.7+17.10.20170616-6ubuntu4) ... Selecting previously unselected package gir1.2-udisks-2.0:arm64. Preparing to unpack .../2-gir1.2-udisks-2.0_2.9.4-1ubuntu2_arm64.deb ... Unpacking gir1.2-udisks-2.0:arm64 (2.9.4-1ubuntu2) ... Selecting previously unselected package gir1.2-unity-7.0:arm64. Preparing to unpack .../3-gir1.2-unity-7.0_7.1.4+19.04.20190319-6build1_arm64.deb ... Unpacking gir1.2-unity-7.0:arm64 (7.1.4+19.04.20190319-6build1) ... Selecting previously unselected package usb-creator-common. Preparing to unpack .../4-usb-creator-common_0.3.13_all.deb ... Unpacking usb-creator-common (0.3.13) ... Selecting previously unselected package usb-creator-gtk. Preparing to unpack .../5-usb-creator-gtk_0.3.13_all.deb ... Unpacking usb-creator-gtk (0.3.13) ... Setting up gir1.2-dbusmenu-glib-0.4:arm64 (16.04.1+18.10.20180917-0ubuntu8) ... Setting up gir1.2-udisks-2.0:arm64 (2.9.4-1ubuntu2) ... Setting up gir1.2-dee-1.0 (1.2.7+17.10.20170616-6ubuntu4) ... Setting up usb-creator-common (0.3.13) ... Setting up gir1.2-unity-7.0:arm64 (7.1.4+19.04.20190319-6build1) ... Setting up usb-creator-gtk (0.3.13) ... Processing triggers for man-db (2.10.2-1) ... Processing triggers for dbus (1.12.20-2ubuntu4.1) ... Processing triggers for mailcap (3.70+nmu1ubuntu1) ... Processing triggers for bamfdaemon (0.5.6+22.04.20220217-0ubuntu1) ... Rebuilding /usr/share/applications/bamf-2.index... Processing triggers for desktop-file-utils (0.26-1ubuntu3) ... Processing triggers for hicolor-icon-theme (0.17-2) ... Processing triggers for gnome-menus (3.36.0-1ubuntu3) ... coolpi@coolpi:~$
https://ubuntu.com/tutorials/create-a-usb-stick-on-ubuntu#1-overview
