Form Factor and Rasperry PoE HAT compatibility
Does this board have the same form factor as the raspberry pi 4b? And is it compatible with the Official PoE HAT along with the same mounting screws as the 4b? I see it has the pins but im just unsure
@Wario Except that the miniDP port is different from the micro HDMI of raspberry pi4b, the others are the same, including PoE
@harry-huang thank you so much, i cant tell you how much i appreciate this
@Wario
https://buyertrade.taobao.com/trade/detail/tradeSnap.htm?spm=a1z09.2.0.0.3ce72e8d76YGWb&tradeID=2860426011740331265&snapShot=trueThe POE module in the link has been validated and tested and can be directly supported.
