Full Record of CM5 Running ChatGLM-MNN Big Language Model
This example is based on the COOLPI CM5 32G memory version, and the system is ubuntu20.04.
- Download ChatGLM-MNN project
git clone https://github.com/wangzhaode/ChatGLM-MNN.git
- Compile MNN library
git clone https://github.com/alibaba/MNN.git cd MNN mkdir build && cd build cmake .. # CPU only make -j8 cp -r ../include ../../ChatGLM-MNN/ cp libMNN.so ../../ChatGLM-MNN/libs cp express/libMNN_Express.so ../../ChatGLM-MNN/libs
- Download Models
cd ChatGLM-MNN/resource/models ./download_models.sh int8 cp int8/* ./
- Build
mkdir build cd build cmake .. make -j8
- Run
coolpi@Ubuntu:~/share/ChatGLM-MNN/build$ ./cli_demo The device support i8sdot:1, support fp16:1, support i8mm: 0 Can't Find type=2 backend, use 3 instead load ../resource/tokenizer/slim_vocab.txt ... Done! load ../resource/models/glm_block_0.mnn model ... Done! load ../resource/models/glm_block_1.mnn model ... Done! load ../resource/models/glm_block_2.mnn model ... Done! load ../resource/models/glm_block_3.mnn model ... Done! load ../resource/models/glm_block_4.mnn model ... Done! load ../resource/models/glm_block_5.mnn model ... Done! load ../resource/models/glm_block_6.mnn model ... Done! load ../resource/models/glm_block_7.mnn model ... Done! load ../resource/models/glm_block_8.mnn model ... Done! load ../resource/models/glm_block_9.mnn model ... Done! load ../resource/models/glm_block_10.mnn model ... Done! load ../resource/models/glm_block_11.mnn model ... Done! load ../resource/models/glm_block_12.mnn model ... Done! load ../resource/models/glm_block_13.mnn model ... Done! load ../resource/models/glm_block_14.mnn model ... Done! load ../resource/models/glm_block_15.mnn model ... Done! load ../resource/models/glm_block_16.mnn model ... Done! load ../resource/models/glm_block_17.mnn model ... Done! load ../resource/models/glm_block_18.mnn model ... Done! load ../resource/models/glm_block_19.mnn model ... Done! load ../resource/models/glm_block_20.mnn model ... Done! load ../resource/models/glm_block_21.mnn model ... Done! load ../resource/models/glm_block_22.mnn model ... Done! load ../resource/models/glm_block_23.mnn model ... Done! load ../resource/models/glm_block_24.mnn model ... Done! load ../resource/models/glm_block_25.mnn model ... Done! load ../resource/models/glm_block_26.mnn model ... Done! load ../resource/models/glm_block_27.mnn model ... Done! load ../resource/models/lm.mnn model ... Done! Q: 写一首描绘冬天的诗 A: 漫天雪花飞舞, 寒风呼啸,大地一片沉寂。 冬天的气息弥漫, 银装素裹的世界令人陶醉。 树枝上挂满晶莹剔透的冰霜, 寒风把它们吹得摇曳生姿。 湖面上结满了厚厚的冰, 划着小船的人们欢笑着前行。 冬天是一个美丽而神秘的季节, 让人感受到宁静和祥和。 虽然它带来了一些不便, 比如冷的天气和冰雪的覆盖, 但它也是一年中最美好的时光。<eop> Q:
@george 目前 MNN 量化不彻底,推理时实际还是f16,所以速度还是慢。
而且 不是很稳定,应该说很不稳定,几条就会奔溃杀死进程。 -
@george 作者是阿里达摩院的MNN框架组的王召德,我有他钉钉,我在天天催更
@顾真牛 他如果需要环境调试,我们可以提供。
