coolpi 4b无法启动
烧录百度网盘以下两个固件到sd卡,都无法启动
日志如下:DDR Version V1.07 20220412
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-364-g55ca4fb1c:derrick.huang
NOTICE: BL31: Built : 12:00:02, May 13 2022
INFO: timer_hp_init no valid 32k timer source, use normal mode
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-639-g8e053a881-dev #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #2 Mon Mar 14 09:09:01 CST 2022 aarch64
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9COOLPI LOADER BY YANYI(Nov 02 2022)
DRAM: 3.7 GiB
Using default environment0 2 1 3 6 8 7 9 trsv ln0 mon rx cdr lock timeout
dp@fde50000 disconnected
hdmi@fde80000: detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
rockchip_vop2_init: hdmi0_phy_pll may not define
assigned-clock-parents's node not define
VP0 set crtc_clock to 148500KHz
VOP VP0 enable Esmart0[356x124->356x124@782x478] fmt[1] addr[0xedf21000]
CEA mode used vic=16
mtmdsclock:148500000
dw hdmi qp use tmds mode
Loading order: usb - tf - emmc
resetting USB...
scanning usb for storage devices... 0 Storage Device(s) found
** Bad device usb 0 **
bank id invalid
mmc1 is current device
** Invalid partition 1 **
Card did not respond to voltage select!
mmc_init: -95, time 17
** Bad device mmc 0 **
mmc_init: -95, time 16
LPDDR4X, 2112MHz
I/TC:
DRAM: 3.7 GiB
bus_format: 100a
resetting USB...
bank id invalid
LPDDR4X, 2112MHz
I/TC:
DRAM: 3.7 GiB
This post is deleted! -
@test 不装散热器?
@test 这是没有正确识别到TF卡的系统分区,TF卡先格式化一次,然后重新制作启动盘。
@test 你的loader版本看起来比较早,升级loader试下。卡的分区表异常,格式化一次
